I know how to convert a 25 fps film to 29.97 using tmpgenc by converting the video at 25 fps with 720X480 and using DGPulldown to pull it down to 29.97. I know that DGPulldown can pulldown a 24.975 mpeg, but TMPGEnc won't convert at that frame rate. If I use AVISynth is there some way to convert it so that I can just pull it down and the audio will still be in sync? Or, is there some way to just convert a 24.975 fps XVid to a 25 fps XVid?
If you encode with TMPGEnc at 25 fps it will add one frame every 1000 to bring the frame rate up (no change in running time). Then you can add pulldown flags with DGPulldown. Of course that adds a small jerk every 40 seconds or so.
Intel i7-950 to i7-975 - will I see any difference
By neworldman in forum ComputerReplies: 3Last Post: 16th Dec 2011, 01:59 -
Changing FPS of .h264 loaded in MeGUI w/Avisynth
By karpodiem in forum Video ConversionReplies: 8Last Post: 6th Apr 2009, 10:27 -
Avisynth IVTC and fps
By snidwar in forum Video ConversionReplies: 5Last Post: 27th Sep 2008, 22:11 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 19:17 -
Encoding XVID from 10 FPS source
By dilly323 in forum DVD RippingReplies: 5Last Post: 15th Nov 2007, 00:00
