I had a cool idea that I could add to my site. I was thinking of taking a webcam and setting it up in a local automotive shop here in Madison. You could tune in from anywhere on the site and watch their progress during the day. This would have to be pretty easy to do. What are the different types of webcams out there and price ranges? Cap I know you've had some research into this since you started the membercam.
1. Are there different types of cameras, ie ones that stream video and ones that just upload a new photo every few seconds? What are the advantages/disadvantages of each? How do each of them update/transfer the video to the site?
2. If I went with the one that updates photos every bit, how does it update? Can it be set to run from 9 to 5 and automatically ftp the images up? What is the interval that the images can be set to refresh at? 5 seconds?
Any other info you could provide about webcams would be great! Thanks!
dont think webcams - think ip cameras instead ....
How would they work, does it transmit a video feed? Can I use them with my current shared hosting plan on Dreamhost? How much do they cost?
i use a number of them -- you dont need a dedicated computer btw..
read more here http://www.networkcamerareviews.com/"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Could you fill me in on some more details? I tried looking at the site some but being on dialup here its hard to get much info out of it. Do they do both still motion updating and video streaming? How often can the still pictures be updated? Is it automatic? What price range are the cameras? Can they be set up to be publicly viewable online?Originally Posted by BJ_M
IP cameras can using motion detection so it will record video or save snapshots when motion is detected in the video. You can FTP still pictures and display them on your website. You can use a javascript to update the pictures every 5 to 10 seconds (or however often you want). Price ranges are $75 and up. You can also display them publicly and you can also embed the video into your webpage.
The same site offers web design services that will help you do this: http://www.networkcamerareviews.com/webdesign.html
I need a camcorder to stream HD like a webcam. What can I get ?
By jfmonod in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 21st Oct 2011, 09:33 -
Need help with Plugin needed to view webcam video from a website
By nugentdavis in forum Newbie / General discussionsReplies: 1Last Post: 13th Jul 2009, 03:48 -
Saving Windowslive webcam video stream?
By masadar in forum Video Streaming DownloadingReplies: 1Last Post: 29th May 2009, 10:44 -
how to stream my slef through ustream.tv using IP cam instead of webcam
By hatim_debate in forum Video Streaming DownloadingReplies: 1Last Post: 28th Jun 2008, 17:35 -
Record/capture webcam stream ?
By bat5hit in forum Newbie / General discussionsReplies: 1Last Post: 16th May 2007, 17:33
