I have a some avi files which I want to convert to dvd with a simple menu. Used Roxio Creator 9 suite which seemed to do the job. Problem is, there's no sound when I play them back on my stand alone (Toshiba 210).
However when I checked on my pc using Media Classic DVD Play there was sound on the dvd. For some reason the Toshiba isn't picking up the sound track.
Is this a problem with the conversion or the burn?
1. never use roxio
2. check sample rate - prob. is 44.1 instead of 48"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Ok, what (preferably free) application do you recommend?Originally Posted by BJ_M
Can't find any mention of the sample rate or how to change it.Originally Posted by BJ_M
Just tried convert & burn of one avi file without menu & it's worked fine. Looks like it's the menu that screws things up. Since each avi file is around 45mins I'd like to put 2 onto each dvd.
No sound on ripped dvds
By PaulaAlmeida in forum Video ConversionReplies: 18Last Post: 23rd Jan 2011, 06:19 -
DVDs have picture but no sound through HDMI cable
By berndawg84 in forum DVD & Blu-ray PlayersReplies: 12Last Post: 29th Sep 2010, 05:47 -
No audio sound on DVDs using Nero Vision 5.3.3.0
By dweis in forum Authoring (DVD)Replies: 9Last Post: 25th Jun 2008, 19:06 -
Mono DVDs play with no sound on specific TV
By Bix in forum DVD & Blu-ray PlayersReplies: 10Last Post: 17th Feb 2008, 06:32 -
vob2mpg sound issue with certain DVDs
By YoKnows in forum DVD RippingReplies: 1Last Post: 31st Jul 2007, 20:10
