I recorded a few episodes of 'Friends' TV serial using my Pinnacle PCTV pro tuner card in Mpeg2 format. I then cut out the ads in the serial and joined the clips to a single file. I then converted it to an avi file using MediaCoder app and used the xvid encoder.
The conversion finished well and first few times I played the video without any trouble. But now, in Windows Explorer, when I just click on the file to open it I get an error saying :
'Windows Explorer has encountered a problem and needs to close '. And then the explorer reloads.
This happens everytime I click on the file. I captured some test clips and converted them to xvid using MediaCoder and even these new videos give me the same error.
What could be the reason?
There are two possibilities I can think of. Does Explorer crash on other files using the same codec? If so, it's likely a corrupted codec.
If it only crashes on those particular videos, then the video file is likely corrupted. You can try turning off the 'Details' box in Explorer, and definitely don't use the 'Thumbnails' settings under 'Views' in your video folder. If Explorer can't open a video, it usually crashes.
I have had a few messed up videos that would do that. Try reprocessing (Re-encoding) one and see if that helps. If so, you have a problem somewhere in the handling of the video, probably at the editing or joining stage. -
regsvr32 /u shmedia.dll to disable the preview. regsvr32 shmedia.dll to re-register if it doesn't help.
I just reinstalled the xvid codecs and now the videos seem to run properly. Havent got the explorer error so far. Thanks for the replies!
When converting video captured with a tuner card...
By CursedLemon in forum Capturing and VCRReplies: 5Last Post: 7th May 2011, 15:13 -
Help Choosing Capture/Tuner Card...or Other wise
By drtalk in forum Capturing and VCRReplies: 2Last Post: 3rd Sep 2010, 17:46 -
How do capture cards get audio when using tuner
By GLE3 in forum Newbie / General discussionsReplies: 1Last Post: 19th Mar 2010, 13:33 -
tv tuner/analog capture resolution problem
By cooldude859 in forum Capturing and VCRReplies: 4Last Post: 13th Dec 2007, 01:16 -
Are all US tv tuner capture devices going to ATSC models??
By yoda313 in forum Capturing and VCRReplies: 6Last Post: 13th Jul 2007, 14:26
