Can anyone recommend a good cd burner.Ive tried nti-cd maker,
I use Nero for CD burning mostly, but ImgBurn will burn most formats of CDs and it's freeware. Considering most of us burn CDs with DVD burners, it may be a good choice. And it's freeware. But most any burning program will do CDs well enough, even the one built into Windows.
And this is not really concerning 'Software Playing'. Moving you to the Computer Forum.
For Free there is a good one, can even run it off a thumb drive .... Burns CD, DVD's and Does ISO Images as well ... No ad's no spyware ....
DP CD DVD Burner
http://www.paehl.de
http://www.paehl.de/dp_cd_dvd_burner.exe
"I Drank What??" - The Last Words of Socrates
SuSE 10.2-32bit -- AMD 1.2 GHZ 1.2 Gigs O' Ram
Fedora Core 6/Winblows Server 2003(Dual Boot) -- Intel 3GHz 512MB Ram
Mandriva 2007 -- Thinkpad 600E
DSL (Dang Small Linux) -- Off thumb drive -
You can try freeware CDBURNERXP to burn CD's & DVD's.
http://www.cdburnerxp.se/download.php -
InfraRecorder may be new to this community but so far it seems stable.
http://infrarecorder.sourceforge.net/
It's another Frontend for CDRecord and has a conventional layout. It should look familiar to anyone who's tried a few different burning apps.
The are three versions; for Win9x-Me, for Win2k-XP (labeled unicode), and even a version that i'm currently trying on my WinXP_x64 system (the lost OS).
The software looks friendly but i can't say it's great since i just started using it.
I don't know if it works with Vista.
--edit--
Well i guess it does work on Vista.
Could someone recommend a good SATA CD/DVD burner?
By Jonathan in forum DVD & Blu-ray WritersReplies: 7Last Post: 25th Feb 2011, 00:41 -
What's A Good Burner These Days?
By MOVIEGEEK in forum ComputerReplies: 5Last Post: 17th Sep 2008, 23:54 -
Good DVD burner?
By whoisquilty in forum MacReplies: 1Last Post: 27th May 2008, 14:33 -
Good CD/DVD data Burner
By Hikari112 in forum Newbie / General discussionsReplies: 4Last Post: 10th Dec 2007, 20:30 -
Reccommend a good burner for max compatibility?
By Bansaw in forum Authoring (DVD)Replies: 11Last Post: 25th Jul 2007, 21:19
