Hello,
I was able to capture every episode of a cartoon I used to love as a child that will never get released on dvd. I have some jpegs of character sketches and stuff like that. I want to make it an extra on the dvds I'm authoring, kinda like on some dvds where you have to use the skip chapter/back chapter button to see each separate image. I'm wondering how to do this. Is it just mpegs that are created of the jpegs that have a never ending loop and remain on the screen until you select the next one? I only have experience with tmpgenc dvd author and pgcedit though. Thanks
The simplest way to do this is to use menus. Make each picture a menu page, and use hidden buttons that auto execute to link to the next menu in the chain. You can then use the right and left arrow buttons instead of next and previous chapter.
If you used something like DLP you can add commands to chapter points, so you could create a single video with all your images, add chapter stops where they change, then add a hold to each chapter stop so the image pauses until the user moves on. You can possibly recreate this in TDA and PGCEdit by creating the chapter stops in TDA, then adding the commands in PGCEdit afterwards.Read my blog here.
Resizing videos and creating multiple DVDs in batch?
By DVD_Noob in forum Newbie / General discussionsReplies: 1Last Post: 8th Dec 2010, 02:40 -
Creating anamorphic DVDs from divx
By Kusie in forum Video ConversionReplies: 5Last Post: 18th Feb 2009, 07:24 -
need info on creating new menus on dvds
By TazDevil in forum Newbie / General discussionsReplies: 2Last Post: 13th Jan 2008, 16:55 -
From 2 DVDs creating one DVD
By asadfx in forum Newbie / General discussionsReplies: 1Last Post: 14th Dec 2007, 02:56 -
Creating DVDs from h.264 files
By bltkmt in forum Newbie / General discussionsReplies: 18Last Post: 31st May 2007, 19:24
