I have some stuff on a VHS tape that I've captured onto the computer.
There is a small tape glitch a few minutes in, where the audio stops for a second and a few silver lines flash across the screen, as VHS tapes are wont to do.
I usually use Screenblast Movie Studio to edit my VHS tapes (cut off the beginning and end of the capture, which aren't the wanted content), but the tape glitch causes it to think that the audio is not the same format throughout the tape. Thus, there's no audio after this glitch occurs.
It plays fine in media player and suchlike, though, as well as working perfectly in movie maker. However, movie maker is too prone to illegal operations to find the time to render the footage.
I need a free piece of software that can cut and re-render some video, and won't balk at the small tape glitch.
Any suggestions?
Results 1 to 15 of 15
tmpgenc plus comes with a 14 day demo of their mpeg2 encoder, plus their mpeg tools. I suspect that this was being suggested as a possible way to cut out the glitch.
Read my blog here.
It says it limits output to half an hour, too.
I have three hours of footage. -
I totally second that - free and very handy.Originally Posted by Abond
I also use a variant, VirtualDubMod - it handles the audio streams slightly differently and, to me, a bit better once you're used to it. Also free.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
VD can't handle the interleaved audio stream or something. I forgot to mention that in my first post.
It sounds like you've got Type 1 DV AVI and you need Type 2 (or vice versa - I never can remember which VirtualDub prefers). Run your DV AVI through either Canopus DV File Converter or Ulead DV Type 1 to DV Type 2 Converter and then retry in VirtualDub. Both are free and there's no quality loss, just re-arranging how the audio is stored in the DV AVI file.Originally Posted by koberulzThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Canopus only works on files smaller than 5.6 GB, DV Type 1 to Type 2 Converter keeps "not responding".
Hmm... Can you recapture and select Type x (whatever x is opposite to what it was)? I know you've 3 hours of videos...Originally Posted by koberulz
The alternative is to use VirtualDub to chop the DV AVI's into chunks smaller than 5.6Gb - I'd say do this to get only one 5.6Gb chunk to run it through the Canopus converter as a trial and, if it works, go with the rest. Use VirtalDub in "Direct Stream Copy" mode and make a note of the exact (and I mean precise, exact) frame number you cut on so you know where to cut next time, and the time after that etc...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Troubleshoot vdub captured audio glitch
By cybertheque in forum Capturing and VCRReplies: 2Last Post: 19th Oct 2008, 11:51 -
Sony Mini-DV camera glitch, what is causing this?
By tarrickb in forum Capturing and VCRReplies: 8Last Post: 25th Nov 2007, 21:41 -
Glitch In Video Causing Audio To Off-Sync
By Squid_uk in forum Newbie / General discussionsReplies: 2Last Post: 2nd Nov 2007, 11:51 -
Converting audio with glitch
By koberulz in forum Newbie / General discussionsReplies: 28Last Post: 7th Sep 2007, 05:55 -
Audio glitch with MeGUI
By KnightHeart in forum Video ConversionReplies: 0Last Post: 7th Aug 2007, 21:21
