Looking for a simple, small and free (or trial-based but will let me export) program to create a simple white-on-black rolling credits sequence. The only thing is I need to be able to paste text into it, and a lot of it (IE: an IMDb credit listing). Anything out there? I tried BluffTitler, but it's not letting me paste the entire text.
Hi-
If you're handy with AviSynth, here's a function that does what you want:
http://avisynth.org/VScrollTitle
And a search on this site turned up this:
https://forum.videohelp.com/viewtopic.php?t=316012
and maybe the best:
https://forum.videohelp.com/viewtopic.php?t=99389
Or:
http://forum.doom9.org/showthread.php?threadid=89319 -
Also MS Movie Maker does a reasonable job. You can output to DV-AVI or WMV.
Best stuff is in the option menu. If you don't like the vertical scroll, check the fade in/out. -
The problem with all of this stuff (near as I can tell) is that I can't copy and paste the text into the field. Oh, well. Thanks for the help anyway, I think I might have to do this manually. I can use Pinnacle, I just have to physically type it out.
Not true, cut/paste works here. I recall reading somewhere credit rolls can be imported as Excel XLS or database. I think that was for Movie Maker. It could have been Premiere. Google should find it.
PS: This doc shows how you can cut/paste from Word into Vegas.
http://www.videoguys.com/Vegas_Tips/TTS02-09.pdf
Rolling Shutter and Deshaking
By blewyn in forum EditingReplies: 8Last Post: 5th Feb 2012, 15:45 -
Can rolling closed captioning be used as subtitles?
By jeanpave in forum SubtitleReplies: 4Last Post: 11th Jun 2010, 12:58 -
rolling/jumping with VHSc
By highaim in forum Newbie / General discussionsReplies: 2Last Post: 25th Jul 2009, 21:03 -
Tools for Rolling Credits
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 28th Apr 2008, 15:53 -
How Do I Split screen Half Rolling Credits-Half Video in Vegas
By Ray & Paula in forum EditingReplies: 1Last Post: 7th Apr 2008, 08:35
