How to add chapters in VCD/SVCD easy? How do i do that on a already encoded movie? I would like to press next on my remote and jump say 15min in the movie....is this possible?
Regards Abel
i cannot even find vcdeasy - been using ulead movie maker, but i get overflow errors when i add chapters, and i cant fast forward on svcd
you can start by reading sefys vcdeasy guide
http://www.vcdhelp.com/DVDConversionGuide/index.php?id=dvdtovcd4c.html#VCDEasy -
Thanks for your ansvers!
But if i use VCDEasy to do chapter, do i have to use it to burn also?
Abel -
the burn option in VCDEasy uses CDRDAO i think. CDRDAO is a great tool for burning. but you dont have to use it. just burn the cue/bin in any program that can. (cdrwin, blindwrite, fireburner or nero(?) )
Well, I am the slime from your video.
Oozin' along on your livin'room floor. -
VCD Easy being a GUI to VCDImager, creates CUE/BIN images.
Now, you can also use VCD Easy as a GUI to CDRDAO which will burn that image onto a CD-R/W.
Or, you can use a variety of other programs:
http://www.geocities.com/medinotes/vcd/burning_cuebin_images.html
http://www.vcdimager.org/guides/burning_cuebin_images.html (mirror)
Regards.Michael Tam
w: Morsels of Evidence -
I used VCDEasy for the first time yesterday....works a treat.....I couldnt get CDRDAO to work for some reason but i just used Nero to burn the cue/bin file to CD.....
Contrary to the info that Nero didnt handle cue/bin very well, it all worked well, the SVCD plays in my Standalone no problem and the chapters are a nice touch -
Thanks for your help!
I'll give the built in burning prog a try then.
Regards Abel
Easy way to add a Countdown Timer to a video
By kelemvor in forum EditingReplies: 0Last Post: 15th Jun 2010, 22:18 -
Add chapters (at least) to already made DVD
By tge101 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Apr 2010, 13:16 -
Easy Add Subs to episodes
By KnightHeart in forum SubtitleReplies: 2Last Post: 22nd Jul 2009, 14:34 -
Easy way to add borders to h264 video?
By cbl016 in forum Newbie / General discussionsReplies: 2Last Post: 10th Oct 2008, 02:51 -
EASY DvD to Divx Ultra (with chapters)
By daisbrown0722 in forum DVD RippingReplies: 3Last Post: 16th Aug 2007, 20:26
