Well, still having problems here:
1.I can now hear the sound, but very low. If I switch to composite or S-Video, the sound level is normal. But no picture.
2. When I try to capture, I get a message like this:
"Virtual Dub Capture Error - Error 424 - Can't open video device"
//Mikke
<font size=-1>[ This Message was edited by: Mikke on 2001-07-01 14:38:00 ]</font>
#2 sounds a lot like what happens if you try to capture more than 240 lines with the overlay enabled. If you're in overlay mode, switch to preview mode by pressing P. (The preview isn't as smooth.)
Regarding #1, are you describing the sound on the captured file or the sound you hear live? If you're describing the live sounds, try a test capture to see if it has the same problems. The recorded sound could be fine, or it could be worse.
tacosalad,
some correction - 240 lines for NTSC.
For PAL VCD, there will be 288 lines.
Mikke,
1.
Try to adjust sound setting in playcenter - sometimes it overrides the Windows settings.
If there still will be no good sound, try to plug your audio to microphone jack and select +20 Db option.
The sound quaility wouldn't be DTS, but it could work for you.
2. This is common problem with PCTV. I set the preview option to off in VirtualDub if I want to grab more than 352x288.
TheRookie
Well I tried preview mode instead of overlay. I cliked on capture video, and my screen turns blue, then I just had to restart my computer(I'm using Windows 9
Sound: Live, since I havent been able to capture anything yet...
//Mikke -
Mikke,
Did you tried to switch previw off?
I mean not to set it to preview or to overlay, but switch it off at all (no video could be seen).
I am able to capture more than 352x288 when I switch it off.
TheRookie -
Thanks for your help, but I don't care anymore.
I'm just using PCTV Vision.
Thanks!!!
//Mikke
pinnacle pctv 310i
By marc21782000 in forum Capturing and VCRReplies: 10Last Post: 4th Jan 2010, 02:30 -
Pinnacle PCTV HD Pro Stick, my experience
By vhelp in forum DVB / IPTVReplies: 46Last Post: 14th Oct 2009, 19:36 -
What software for Pinnacle PCTV HD?
By tomreedtoon in forum Capturing and VCRReplies: 10Last Post: 9th May 2009, 06:14 -
Audio problems with Pinnacle PCTV HD Pro Stick.
By cactusjack310 in forum AudioReplies: 0Last Post: 21st Jan 2008, 17:16 -
Which is best, Pinnacle 110i or PCTV Pro PCI
By brvignesh in forum Capturing and VCRReplies: 23Last Post: 28th Nov 2007, 22:40
