I have burned several DVD's using DVDFab Decrypter and DVD Shrink successfully. I recently upgraded my Nero Program to Nero Essentials, and now I keep getting error message that DVD burn has failed. I can successfully rip the DVD's to file, and then re-encode using either DVD Shrink or Nero Recode, but when it starts the burn process, I get error message and no burn.
I don't know where to go from here. Is it bad media?, or something else.
Any help would be greatly appreciated
If you are using Nero to automatically burn with DVD Shrink, newer versions of Nero won't work. You still can burn it by using 'DVD-Video' mode in Nero Burning ROM and drop the contents of your VIDEO_TS folder into the Nero VIDEO_TS folder.
Instead, use ImgBurn. You can use the 'Build' mode to burn the VIDEO_TS folder to DVD. Or use a version of DVD Shrink that can burn with ImgBurn automatically: http://forum.digital-digest.com/showthread.php?t=63869
If ImgBurn doesn't work, then you might consider trying other media.
And welcome to our forums.
Problems converting recent mkv's to ps3 format!??
By josetjr in forum Video ConversionReplies: 1Last Post: 25th Sep 2010, 06:15 -
Super C Problems - Recent Version
By PowerFalcon in forum Video ConversionReplies: 6Last Post: 18th Jun 2009, 19:04 -
Problems Burning Movie Files onto blank Dvds-RW disks
By tealmarlin in forum Newbie / General discussionsReplies: 35Last Post: 1st Jan 2009, 11:18 -
help burning dvds
By bunty90 in forum Authoring (DVD)Replies: 2Last Post: 3rd Aug 2008, 12:53 -
Burning HD DVDs...Help!
By Anonymous55 in forum Authoring (DVD)Replies: 6Last Post: 14th Jun 2007, 20:37
