I want to upload many dvd footage into my computer to make videos. I was thinking of iSofter DVD Ripper Platnuium. Anyone have any advice on what to get? I of course want it to convert it to WMV or AVI files form the DVD Source.
I've never heard of that program.
For just ripping DVDs to your hard drive, DVD Fab Decrypter works well, RipIt4Me is more versatile. Both work with the newer DVD encryptions. For older DVD encryptions, DVD Decrypter is one of the best rippers. These are all freeware and work better, IMO, than any payware programs out there.
After the DVD is ripped, you want to convert it to a different format? You could also rip with VOB2MPEG and that would give you a MPEG of the main movie, which you could convert to any format you want. There are no quality losses with this, as it just extracts the MPEGs from the DVD. And you don't have to deal with the VOBs, etc.
Or you could use AutoGK, or FairUse Wizard if you wanted to go from DVD to Xvid or Divx in more or less one step. This will give you a Xvid or Divx file of 700MB for CD use in fair quality, or better, a file of about 1.5GB with good quality.
I wouldn't convert to WMV, unless you have a particular reason. Xvid or Divx would be a better format, IMO. -
I would convert to WMV or AVI so I can upload it into Windows Movie Maker. The VOB2MPEG doesnt format it to upload into Windows Movie Maker.
Originally Posted by Sudden ImpactIf in doubt, Google it.
Xilisoft Blu Ray Ripper - Does Anybody Test This Program?
By devilcoelhodog in forum Blu-ray RippingReplies: 4Last Post: 24th Mar 2011, 14:03 -
Using All-In-One DVD ripper
By shuohshuoh@trashmail.net in forum DVD RippingReplies: 2Last Post: 11th Apr 2010, 12:47 -
Best DVD ripper?
By nj473 in forum Newbie / General discussionsReplies: 5Last Post: 2nd Mar 2010, 15:42 -
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 08:42 -
Can someone recommend a freeware program similar to AOA dvd ripper?(youtube
By tecmobo34 in forum Newbie / General discussionsReplies: 2Last Post: 28th May 2007, 16:16
