  1. Hi,
    I have an AC3 audio which play fine, i use Besweet to convert it into mp3 which play fine as well, but once i convert it into Wav (to increase the volume) or into AAC/mp4, i get a glitch sound during 3 seconds silent in the middle of the audio.
    it look something like this.
    start---------playing normal-----fade out----silent for 3 seconds----glitch sound----fade in sound---playing normal---end.
    Is there any program out there that i can open this audio, then highlight the glitch part and replace with a silent?
    thankssssssss
  2. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    Originally Posted by bennyvo
    ... Is there any program out there that i can open this audio, then highlight the glitch part and replace with a silent?
    Audacity can.
    Buy My Books
  3. Member gsing's Avatar
    Feb 2007
    Wurstland
    Maybe try a different converter tool like DAudioK
    Dec 2006
    Australia
    thanks gadgetguy i think audacity will do the trick...
    as for gsing method, i would give that a try too since it also have a normaliser, this is the reason why i use besweet. i have try other normaliser but it doesn't seem to increase the sound(loudness).
    thanks both
