Feature list:
High-definition Blu-ray Disc authoring
Maintain the pristine quality of your HD video all the way to distribution. Create high-definition Blu-ray Discs with the same Encore interface and features used to create standard-definition DVDs.
Publishing to the web
With one click, easily create SWF versions of your DVD and Blu-ray Disc projects for the web using Encore CS3. Produce content compatible with Adobe Flash® Player, complete with DVD interactivity and menus, without opening another application.
Author once, and then deliver to three formats
Reach more audiences quickly. Automatically convert your high-definition Blu-ray Disc projects to standard-definition DVDs and interactive versions for the web.
Slideshow Editor
Build and arrange slide shows with ease. Define shows as browsable or autoplay with optional narration or music. Set slide durations, add transitions, and apply pan-and-zoom effects.
Flowchart
Define and view the navigation of your DVDs, Blu-ray Discs, and SWF files by using a visual flowchart representation of all points and links.
Automated chapter menus
Create multipage menus automatically from chapters or slide shows in your project.
Flexible input file support
Work with AVI, QuickTime, WMV, H.264, and MPEG-2 source files to build your DVD or Blu-ray Disc navigation, and then encode them as MPEG-2 or H.264 video assets when you are ready to burn your disc.
Adobe Encore CS3 included in Adobe Premiere Pro CS3
Adobe Premiere Pro CS3 ship by July 2007
http://www.adobe.com/products/premiere/encore/allfeatures/
First authoring software that export DVD project to flash.
Its useful if you want convert DVD to CD for PC. -
Very nice:
http://www.academicsuperstore.com/market/marketdisp.html?PartNo=798247
(if you qualify)Want my help? Ask here! (not via PM!)
Interesting.
The Macromedia acquisition is producing results
http://www.kiva.org/about -
That's what I was thinking. I'm most interested in this:Originally Posted by edDV
With one click, easily create SWF versions of your DVD and Blu-ray Disc projects for the web using Encore CS3. Produce content compatible with Adobe Flash® Player, complete with DVD interactivity and menus, without opening another application.Want my help? Ask here! (not via PM!)
Can any of these products do Hi-def on DVD ala Microdvd on Cd. and is hi-def on dvd a std??
ULead Movie Factory does MPeg2 HD DVD to DVD-5 (~20min) or DVD-9 (~40min). AVC MPeg4 (VC-1 or h.264) can approximately double those figures DVD-9 (~78min).Originally Posted by RabidDog
DVD Forum -
Sorted.. 20 mins is long enough for any porno, sorry promo clip!
How do you use Adobe Encore CS3?
By Banleno007 in forum Authoring (DVD)Replies: 2Last Post: 20th Feb 2012, 12:33 -
Normalize audio in Adobe Encore CS3?
By Benhermies in forum Authoring (DVD)Replies: 3Last Post: 31st Aug 2008, 03:11 -
By Benhermies in forum Newbie / General discussionsReplies: 1Last Post: 29th Aug 2008, 13:40 -
By zanos in forum Authoring (DVD)Replies: 0Last Post: 24th Apr 2008, 22:04 -
Adobe Encore CS3 - quick way to create 100 menu links?
By sdsumike619 in forum Authoring (DVD)Replies: 10Last Post: 4th Apr 2008, 23:17
