I would like to take some of the soundtrack from a DVD film and turn it into an editable WAV or MP3 file to be imported into Liquid Edition.
What is the simplest way to do this? I'm assuming I need to rip the DVD to isolate then convert the audio track...
I only want small bits of the soundtrack (mainly some sound effects I like).
Cheers for any advice
Actually DGMPGDec can save part or all of your DVD audio by vobs.
Just add the vobs you want, review & save "project" to a folder...audio will be there.
You'll then have to convert...
I use HeadAC3.
http://www.ligh.de/software/HeadAC3he_0.24a13.rar
Both apps are freeware, and "no-install" (run from download/any folder)The Devil`s always.....in the Details!
Ripping Soundtrack from DVD
By Charmer in forum DVD RippingReplies: 21Last Post: 12th Aug 2010, 11:27 -
How can i change soundtrack ?
By forcedv in forum Newbie / General discussionsReplies: 2Last Post: 20th Apr 2009, 09:48 -
normal audio cd from a dvd movie soundtrack
By hilario in forum AudioReplies: 19Last Post: 19th Nov 2008, 16:50 -
Soundtrack problem
By Den-2 in forum Video ConversionReplies: 2Last Post: 23rd Mar 2008, 09:42 -
Editing DVD soundtrack
By dac in forum AudioReplies: 2Last Post: 22nd Mar 2008, 01:53
