Hello guys,
I've got a little problem.
When i'm watching a movie(doesn't matter if it's a dvd or avi or mkv) my monitor shuts off after a few minutes. When using Powerdvd, i can only watch 1 minute or less, and my monitor shuts off. I cannot turn my monitor on, even when i plug a new monitor on, it still is black.. Everything else runs fine, sound, programs, only i can't see a thing..
I tried this:
Powermanagment is set on always on..
Newest videodrivers
Newest codecs
No overheating problem
I think the problem lies within the videocard + software stuff. But i don't know exactly where to start..
tnx for the help..
I could be wrong but this sounds like an overheating problem to me.
If your videocard has a cooling fan on it make sure it's still working and alos check any case fans are working. Might also me worth cleaning any dust out while you are in there.
I'm assuming that on the desktop there is no problem it's only when showing video - which suggests your videocard is doing the decoding whihc in turn suggest (to me) a possible overheating problem.
Other obvious things to try is using the monitor on another computer (eliminate the monitor as the source of the problem) and try a different monitor on your computer.
Depending on when the new drivers were installed it could be worth rolling back to the previous versions and see if that makes any different. -
i've connected my monitor to another pc, but no problem. If i plug another mon to my pc. It does the same wacky thing.. And it's no overheating prob, i've got my programs checking. There all at 36 degrees when running movie.. The fans are running. I'm testing older drivers now.. So i'll be posting the results later..
nope, it's not the drivers problem, tried the old and beta drivers.. no succes
Try to reinstall the latest DirectX or try to reduce the Hardware acceleration to see if it's help
Options for playing RCA video on my computer monitor?
By will7370 in forum Newbie / General discussionsReplies: 1Last Post: 8th Mar 2012, 22:55 -
Questions about connecting a DVD Player playing to computer monitor
By Akastn20 in forum Newbie / General discussionsReplies: 2Last Post: 18th Jan 2012, 00:15 -
Playing 1080p video on a higher res monitor
By Long Hot Summer in forum Newbie / General discussionsReplies: 6Last Post: 8th Jan 2011, 05:25 -
Playing and Recording (xbox360 at the same time on one SD monitor with BMIP
By Lumpylala in forum Capturing and VCRReplies: 3Last Post: 17th Jan 2010, 14:32 -
Monitor shuts down
By jyeh74 in forum Newbie / General discussionsReplies: 8Last Post: 1st Oct 2007, 20:00
