  1. I just loaded thunderbird (version 1.5.0.10 (20070221) ) and noticed my emails from after august 2006 have gone. Now I had some problems before, with symantec moving the profiles etc, but I solved that and it doesn't delete the profiles. So I'm not sure exactly what has happened, and I can't think of a reason why this would have happened.
    How would I go about trying to retrieve them back? All the sent folders/trash/other folders are accurat and up to date, it's just the inbox folder missing emails...
    cheers! I'm quite worked up lol, and need to chill down.
  2. Member tekkieman's Avatar
    Mar 2004
    Over the hill
    Have you verified that the program is pointed to the correct account, or to the global account? Also, if you configured a new account during setup, it is possible the missing emails are still in the global inbox (or the other way around).
  3. I just have one account/inbox, and haven't added any actually. So I guess thats ok there.. ?
  4. http://www.the-pc-guru.com/Thunderbird_problems_build.php
    Hmmm I tryed number 1 on here, didn't work so I just copied the fules back, and that didn't work either. I then start up mozilla for the third time, and they are back! Mysteriois stuff lol
    thanks for your response grizz
  5. Member ahhaa's Avatar
    Feb 2005
    Michigan USA
    JJ-
    Mozilla has a forum & bug report form- it'd be good if you report this anyroads... for the rest of us!:]
  6. This seems to happen when you load t-bird over t-bird ...., it seems to kill your profile sometimes, but your e-mails still exist..... I posted something for this in a suse forum, I am sure it will work for windows as well ...
    http://opensuse.us/phpBB2/viewtopic.php?t=1865&highlight=thunderbird
    "I Drank What??" - The Last Words of Socrates
    SuSE 10.2-32bit -- AMD 1.2 GHZ 1.2 Gigs O' Ram
    Fedora Core 6/Winblows Server 2003(Dual Boot) -- Intel 3GHz 512MB Ram
    Mandriva 2007 -- Thinkpad 600E
    DSL (Dang Small Linux) -- Off thumb drive
