I have a 3 hour long .mpg captured from VHS at a 15,000 bitrate which I need to cut into around 10 different .mpg's, order swapped around, title screens placed in between and put back together to then form an ~8000 bitrate DVD compliant .mpg. I have access to any Adobe software and don't mind purchasing some cheaper software if need be.
How do I go about doing this? Will the video quality suffer (numerous re-encoding?) from cutting and moving sections around?
Don't cut it, just import it in Premiere and edit as you like. Then export it as a DVD compliant MPG. You'll need an authoring program to format things and make a menu. DVD Author GUI is free, I like TDA (not free) and you might already have Nerovision (some don't like it, but if your MPG is DVD compliant it won't re-encode).
An alternative would be to do your rearranging in Mpeg Video Wizard DVD - it's specifically written to handle MPG as an input and only re-encodes where it needs to (around the cuts) and not the whole MPG (I'm not suggesting Premiere does - in fact, I don't know).
Once done, output to MPG and then use ReJig to reencode down to a DVD compliant bitrate file.
nic2k4's suggestions for authoring tools would be the ones I'd suggest if you're starting out. Of course, if you're experienced and know how to use it, then having access to Adobe's Encore is an option.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Thanks guys, just to double check whether I've understood this right,
I can import the whole 3hour .mpg into Encore (or Premier), cut the .mpg up and move sections around, insert title screens (with the help of photoshop & after effects), and then re-encode everything in Encore to a DVD compliant .mpg? Thus Encoding will only happen once on the whole final .mpg?
By DVD compliant, will Encore output vobs, etc?
What's the difference between Encore & Premier? -
I've never used Encore, so I had a look at Adobe. From what I can tell Premiere is used to edit the video footage and create the actual movie. Encore is the DVD mastering program, used to setup how to navigate the DVD and pick between all the movies and segments inside a movie on the disc. You would insert title screens in Premiere from Photoshop or After Effect. You would insert menu graphics (background, buttons...)in Encore from Photoshop.
Just put your 3hr footage in the media bin, then drop it on the timeline, set the entry and exit points for the first clip. Then grab the footage from the bin and drop it again on the timeline set the entry and exit points for the next clip... -
Originally Posted by nic2k4There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Originally Posted by EViS
Since your starting with 15,000 to begin with it has to be reencoded so this may not be of concern to you.
MPG Files taking a long time to open.
By Ads79 in forum Software PlayingReplies: 8Last Post: 13th Nov 2009, 09:39 -
.mpg -> .mp4 using ffmpeg, Video is choppy and 2x too long
By rccollins in forum Video ConversionReplies: 3Last Post: 11th Dec 2008, 10:20 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 14:48 -
Cutting a MPG FILE
By peekayem in forum EditingReplies: 3Last Post: 16th Mar 2008, 09:06 -
cutting out scenes without loss / converting mpg to avi
By denadel in forum EditingReplies: 3Last Post: 19th Jan 2008, 08:18
