Hi,
Im having trouble capturing video from my vcr, i get an image but it is badly distorted and unwatchable.
Here's the problem:
Im using an ati x850xt pe video card (newest drivers) to record a vhs casette to my pc.
Ive connected a RCA (composite / cinch / yellow) cable to the appropriate input on the graphic card. Im using VirtualDub 1.6.17. I get an image but it is really bad...
Ive tried adobe premiere 2 as well, but it says "device offline"
windows movie maker, gives the same result as virtualdub
im using the ati T200 avstream capture device/driver
edit// the connection is as follows:
vcr > scart to rca adapter > rca cable > graphic card
ive done the following checks:
used the same cable to output video to my tv (without scart adapter) - works
tried my set top box' output - same result as my vcr
used the same scart adapter + same cables to output video from my vcr to my tv's rca input - works
Here's a screenshot from virtualdub:
Hope someone can help...any suggestions are appreciated![]()
I have a very similar setup to you, except I have the X800XTPE. That looks just like the problem I have with VirtualDub if it selects NTSC rather than PAL B as the capture format.
Check this out in VirtualDub under: Video -> Capture Filter
Try putting it on PAL B (that's what we use in Australia, your mileage may vary based on your location).
Also, you will probably find problems not being able to use T200 driver in various apps. The last working WDM was from the Catalyst 6.2 drivers, which I am still forced to use to maintain WDM compatibility with various apps. -
hey
thx for the reply, i was using PAL when i took that screenshot.
i managed to solve the problem...
it was something strange, i just had to select "no driver" and then "T200 driver", in succession, maybe the graphic card was locked in use or something-i donno...
Windows7 image backup - restoring the image question
By ranchhand in forum ComputerReplies: 18Last Post: 15th Apr 2012, 08:13 -
Printed page image don't equal PC monitor's image?
By bryankendall in forum Newbie / General discussionsReplies: 9Last Post: 11th Nov 2008, 14:45 -
Vegas 8 - replace an image with image from previous frames
By sdsumike619 in forum EditingReplies: 2Last Post: 5th May 2008, 15:26 -
image shift in frame with Virtualdub capture
By Knightmessenger in forum Capturing and VCRReplies: 0Last Post: 27th Aug 2007, 01:16 -
Vegas - add image to video (DVD(mpg)) and moving image around
By psxiso in forum EditingReplies: 4Last Post: 11th Jul 2007, 05:29
