Insomniak4700 - That's weird. I wouldn't change the bassaudio filters if I were you. They're tricky and very version specific.
Results 91 to 120 of 202
I removed Avast and installed AVG... less hassle and I really, really want to try this
I'll check in later for a .WAV version. thanks! -
Thanks for sticking in there, guys. I'll have a solution for the WAV conversion and Mpeg2 issues by tomorrow.
Aaron - Download Imago Mpeg Muxer https://www.videohelp.com/~liquid217/ImagoMPEG-Muxer.zip
Edit:
Is it possible that you could make me a program that lets me just click on one file and it converts my .mpg file to DVD format video with 5.1 sound?
i hope you can because that would save me a lot of time because I need to do it like 200-300 times if not. -
Insomniak4700 - Here you go. Turns out it was easier than I thought. Doesn't need the BassAudio dlls either (as long as your WAV files are under 4GB in size).
Unzip, place your WAVs in the same folder and double click the .BAT file to run.
wav_to_5_1_upmixer.rar
Aaron187 - I'll work on the MPEG to 5.1 sound script. This one is really complicated. If it was easy, I would have released it by now
There are some technical hurdles that make it especially difficult, in particular ensuring the output has good A/V sync. It's a lot easier to do for DivX or Xvid AVIs.
dirkenlek - No, the lack of opensource tools for WMV demultiplexing and remultiplexing, and my dislike of the WMV file format make it something I'd rather not take on. It might be technically possible - someone else might have a solution.
What upmix function should I use ?
UpMixHeadphones
UpMixJagger
UpMixFarina
UpMixGerzen
UpMixSOS
UpMixMultisonic
UpMixGeneral
Which one is better for a home-theater ?
I used UpMixFarina, it works well but I got this warning :
"can't rewind stream by 63 bits"
strange -
I've never seen that message before, but it looks like it is coming from FFmpeg. Replace the one in the package with this: http://ffdshow.faireal.net/mirror/ffmpeg/ffmpeg.rev10141.7z
Your source file might be imperfect. Try another file to test.
I like UpmixFarina, but that's just my personal taste. Your ears can judge which one sounds best for you. Jagger posted some additional configs in the thread. -
It comes from wavi, but I tested with another avi sample and works fine
Tested with avi samples and converting NTSC to PAL and vice-versa, didn't encounter sync problems, seems that everything works fine.
I like UpmixFarina, but that's just my personal taste. Your ears can judge which one sounds best for you. Jagger posted some additional configs in the thread.[/quote]
Ok, I used that also
Can I use this scripts for free ? i.e., can I include them in public projects ?
thanks -
Here's a newer version of WAVI: http://sourceforge.net/project/showfiles.php?group_id=196137
Of course you can use the script and associated apps in any other not for sale project, but you have to include the source files and should include urls to the programs as well. Read the readme. -
Oh okay thanksOriginally Posted by Soopafresh
. sorry im putting u throuhg lots of trouble but i really appreciate it
No problem, just have patience my friend. I'll try to get it working this weekend.
Q - Do all of your files have MP2 audio ? -
Yeah I am sure about the MPEG-1 Layer 2 audio but I am not sure they will all be mpeg2 video but they will all have .mpg extensions
Of course you can use the script and associated apps in any other not for sale project, but you have to include the source files and should include urls to the programs as well. Read the readme.[/quote]
Nothing to sell, but everything to give for free, I do this only for fun and sport
You can see it working with CCE SP2...HC Enc...whatever....in just one click
well...if you have a good sample, as I said...it is a little unstable with bad sample sources.
www.avi2iso.com
should be easy to you to understand how it works, all-in-one it's all the same...or not !!!
I made some little changes, let me know if I am missing something with your credits
thanks again -
This batch already does multiple formats including *.wav to *.ac3 5.1.
https://forum.videohelp.com/topic326127-30.html#1746651 -
Yeah nice program you have there in AVI2ISO !!Originally Posted by Delta2
And finally a 1 click converter with Low Pass Filter turned off in CCE SP2
But with the scripta.avs and stereo.bat being generated by the main program, I can't
change the upmix script from Farina and the bitrate is stuck on 384. -
Thanks for your nice words, I tried to make a all-in-one as simple as I could, that's why I made 3 profiles as you notice.
I used your defaults with UpMixFarina method, less than 256kbps for 5.1 it is very low
It is foolish to think that a all-in-one developer understands everything so....I will be very grateful if you helped me to make this more perfect...it is beta as I said in my homepage
Thank you very much -
soupafresh, I was just wondering if the wav script you send me did some kind of levels adjustment? It seems so much simpler than the mp3 script....
I was just wondering because I wanted to try it with a TV movie capture.. -
Get rid of this section if you don't want the volume changed (so much). There are going to be some volume changes, especially with the original script on the first page using UpMixFarina. But that's by design for movies vs music. With WAV audio as your source, I'm assuming you are upmixing music, so the output isn't as dynamically compressed.
for %%a in ("*.wav") do @echo ConvertAudioToFloat().SSRC(48000).normalize() >>"%%~na.avs"
Or, try j4gg3rr's version, posted above. -
Aaron - Try this one http://www.savefile.com/files/1043358
Place your MPG files in same folder and click .BAT to run
When Complete, the 5.1 Upmixed files will have .VOB extensions
* Note - It's not very smart. It won't know if your source file is Mpeg1 or Mpeg2, or if your Audio is MP2 or AC3. It'll work if your file is MPEG2 video with MP2/MPA audio. Make sure you have plenty of free disk space. -
No promises. Like I said, there isn't any intelligence built in, so your files that are Mpeg1 or Mpeg2 with 2.0 AC3 audio are going to be rejected. You can open you folder of Mpeg2 in mediainfo and determine their file type before you run them through the Upmixer
http://mediainfo.sourceforge.net/en/ScreenShots/GUI_Main -
They WILL be rejected? or do they have a chance of getting through, because I just edited my MPG2 video file and now it is exporting to MPG1, I can just redo the editing and make it MPG2 but just wondering if it has a chance.
You can try it... See, that's the thing about Mpeg files - there are too many different combinations of video and audio to easily automate it. And demuxing and properly re-muxing the files are tough to do. I would segregate your files into 4 different folders
A) Mpeg2 Video and Mpa/Mp2 Audio
B) Mpeg2 Video and AC3 2.0 Audio
C) Mpeg1 Video and Mpa/Mp2 Audio
D) Mpeg1 Video and Ac3 Audio
The script is designed for files in Folder A. I could modify the batch file so Files in folder B would get converted. -
oh cool. it would be nice to have C but its okay, you helped me alot
I can convert the video myself.
THANKS! ALOT!
To Script or Not To Script, that is the Question... (Custom Videos)
By TheMcD in forum EditingReplies: 2Last Post: 21st Oct 2010, 11:11 -
Does my script look right? I am trying a new script
By rocky12 in forum Newbie / General discussionsReplies: 11Last Post: 25th Sep 2008, 20:10 -
Script error
By buddycat in forum Video ConversionReplies: 8Last Post: 18th Nov 2007, 08:38 -
avisynth script
By magenta2007 in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 25th Sep 2007, 12:29
