I am trying to convert H264 movies to FLV format using ffmpegX. When I convert the same movie as an MPEG4 to FLV it works fine. But the conversion from H264 completes instantly and produces a zero kb file.
Any ideas? Thanks!
Click the blue "i" in the ffmpegX Progress window. Check if the last line in the log reads "Codec type mismatch for mapping". If so, check post #1510792 for a solution.
Thanks! That info in the second post did the trick. Now onto trolling through the forum for optimal FLV encode settings....
I am getting the same problem - instant conversion with a 0kb file
From the info link I get this error
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Fri Apr 13 16:12:39 WEST 2007
Mac OSX universal build for ffmpegX
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x5597b8]negative ctts, ignoring
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/gtchild/Desktop/flower2.mov':
Duration: 00:04:54.3, start: 0.000000, bitrate: 97 kb/s
Stream #0.0(eng), 12.02 fps(r): Video: h264, yuv420p, 320x240
Number of stream maps must match number of output streams
Can anyone help -
Originally Posted by garychild
Yes this is true, there is only video - I will try a file that has audio too.
in the meantime - how would I change the settings to change a video only file - it is a silent animation.
Thanks for your reply -
What form of h264 will VideoRedo h264 tvsuite accept?
By Asterra in forum Video ConversionReplies: 4Last Post: 12th Apr 2012, 13:22 -
H264 to DVD in ffmpegX
By cb678 in forum ffmpegX general discussionReplies: 1Last Post: 19th Nov 2011, 15:36 -
Problems converting some xvid to h264 to append to another h264
By PlanetIndigo in forum Video ConversionReplies: 3Last Post: 6th Jun 2011, 14:13 -
H264/AC3 (MKV) to H264/AAC (MP4) ?
By jccca in forum Video ConversionReplies: 10Last Post: 13th Dec 2008, 19:06 -
H264: Are there other h264 (AVCHD/VC-1) encoding command-line/CLI tools ??
By vhelp in forum Newbie / General discussionsReplies: 12Last Post: 16th Feb 2008, 01:20
