Evertime i conversion bin/cue to mpeg on VCDGear it gives me MPEG Stream can not be found.I have tryed this on 3-4 Diff movies i downloaded. :-? :-?
Firstly, are you sure that they are CUE/BIN images of VCDs?
Secondly, is your eventual goal to burn a disc? If so, then don't extract anything from the CUE/BIN images, just burn them!
http://www.geocities.com/medinotes/vcd/burning_cuebin_images.html
http://www.vcdimager.org/guides/burning_cuebin_images.html (mirror)
If you aren't sure what they are, burn them on CD-RW media so you don't waste any discs.
Regards.Michael Tam
w: Morsels of Evidence -
Well i really one just mpeg stream out so i can watch on the computer and the put it on a VHS Tape :)
Use Daemon-Tools then to mount your CUE/BIN image as a virtual CD.
Then you can see what the CUE/BIN image is actually of...
Regards.Michael Tam
Whats that do mount it?
Hehe im not a n00bie just never hard this problem before
:lol: -
Firstly have some patience. This is a bulletin board, not IRC.
http://www.daemon-tools.com
This is a proggy that will create a "virtual CD drive" on your PC. You can then use it to load a variety of different CD disc images (including CUE/BIN) so that it appears that you have got a physical CD in a CD drive.
Regards.Michael Tam
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 11:36 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 10:11 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 22:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 22:26
