I used avi2dvd to convert my Xvid to dvd. The Xvid was Pal, so I convert it to Ntsc.
Avi2dvd puts it in Dolby Digital 2.0. So played it on my moms dvd player it work fine and it work fine on my brothers dvd player fine 2. Plays on pc fine
I just got a New Sony dvd recorder(RDR-GX330). So I played it my new dvd player, I can't get the sound to work. I use avi2dvd before, they work fine on this player. I try diffrent audio settings on the player with no luck.
Thanks for help
If you need more info just ask
Does the DVD play properly in any other player?
What audio codec was used to encode the original AVI(s)?If cameras add ten pounds, why would people want to eat them? -
Since the disc plays fine in other players, most likely the disc is not fully dvd compliant. Some players are very picky about media and dvd structure.
I seem to remember an issue concerning the audio tracks where some players expect the default audio track to be a PCM track. If it isn't, they will ignore any other tracks even if they are in supported formats. I could be wrong, I haven't seen this issue in awhile. Maybe someone else remembers more details.Google is your Friend -
Ai Haibara
Yes dvd plays fine on 2 other players, and for codec i don't know. I use the HCEnc encoder in
Avi2dvd. I use Avi2dvd on a diffrent dvd, it works fine in this Sony player.
Do thank it has something to do with the Pal to NTSC?
I did not have to concert to NTSC on the other dvd i did
I thank I try diffrent encoders and see if it works.
Thanks for help
sound output of 1 DVD player to another
By Shikhar in forum DVD & Blu-ray PlayersReplies: 16Last Post: 27th Dec 2008, 23:50 -
Magnasonic DVD Player has no sound
By Hadouken in forum DVD & Blu-ray PlayersReplies: 1Last Post: 16th Jan 2008, 12:03 -
Problem with Background sound using AVI2DVD
By govtstooge in forum Newbie / General discussionsReplies: 3Last Post: 21st Dec 2007, 14:11 -
avi2dvd sound problems
By justmenow55 in forum Video ConversionReplies: 5Last Post: 13th Aug 2007, 02:58 -
No sound when playing in DVD player
By blizzery in forum AudioReplies: 1Last Post: 28th Jul 2007, 18:35
