I have 3 AVI videos in, I think, 16:9 format (512 pixels wide and 288 pixels high). In order to author that into DVD using TMPGEnc DVD Author 1.6, I have to make them into mpeg2 first.
If I used 512 x 288 pixels, TMPGEnc DVD Author complained that 512x288 cannot be used for a standard DVD. But if I make it into the formats supported by the tool (i.e. 352x240 , 352 x480, 704x480, 720x480) during the mpeg2 conversion, when viewing the mpeg2 output file, I can see that the image is either stretched or compressed. Can some one tell me what is the right way to do this ?
What do you convert to mpeg2 with? WIth most encoders can you set it to 16:9 and then should tda automatically identify it as 16:9. You can also change the headers in the mpeg with dvd patcher and then import in tda.
what PLAYER do you use to view the mpeg2 file ?
normally I use VLC or mpc, VLC will open the file in the correct aspect ratio ( as specified by the DAR in the header )
some players will display the the video strictly on a pixel*pixel basis and this will not appear correct even though your finished DVD will play correctly
all ntsc USA dvd VOb files are 720*480 whether 4:3 of 16:9 wide screen, the DAR flags tell the DVD player to stretch the picture to 16:9 instead of 4:3
you can try covertX it will covert your avi directly to DVD just set the output to 16:9
or you can CCE to encode to meg2 or mpv elementy stream
or HECnc whic is free , I use convertX on some things
others i use CCE and then author with GFD
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
TMPGEnc DVD Author 1.6...
By acid_burn in forum Authoring (DVD)Replies: 4Last Post: 21st May 2008, 23:45 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
