    Aug 2005
    Right here
    Hi all,
    I’ve recently bought an usb memory stick that, besides a mass storage device, can also run apps without installing in the pc.
    I have found out there is a portable version of Audacity, but can’t find anything else video/audio related.
    The apps that I most use are VirtualDubMod, Tmpgenc, TDA, DVDLab Pro, and EncWavtoAC3, plus Gspot and VideoHelp bitrate calculator.
    Do you know if there are similar apps that can be run from a memory stick?
    TIA.
    They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety. (Benjamin Franklin).
    Apr 2004
    Miskatonic U
    I carry a portable version of audacity, firefox 2 and VLC, all from Portable Apps. Googling for portable apps also found me a few others including a packet sniffer, HDD diagnostics, file recovery tools and a few others. Pretty much anything that has a standalone exe, doesn't need the registry, or can be unzipped to a single folder will work. Virtualdub is a good example. AVIDemux can also be unzipped to and run from a USB key.
    Read my blog here.
    Aug 2005
    Right here
    Thank you very much, guys!!
    Really
  4. also note that almost ANY (Adobe, MS Office, etc) applicaton can be MADE into a portable with applications designed specifically for that purpose.
