hi, i got a new problem with tmpgenc, every video i encode, after its reported as done, i open it up in windows media player and it always reports the video as just under an hour long for instance the last video says its 00:59:53 long, when it should be 01:54:54 long.
I've tried uninstalled and reinstalling the program with no luck, and not sure whats causing it.
I'm using doom9s guide to convert an avi to dvd, just encoding the video part not the audio.
Use to work all the time no problem, encoded over 40 dvds before so i dont know whats screwing it up now.
any help would be great, thanks!
Only virtualdubmod can show you the real duration of elementary video stream. WMP is junk, but there is no player that will show you the real duration of elementary mpeg video stream
yea its running to the end, at normal speed, just have some problems in some author programs, theres manual fixes for the author program, but i was wondering if this is just a normal glitch or theres a fix for it.
2 Hour Long File Conversion ffmpeg
By wsander9 in forum ffmpegX general discussionReplies: 3Last Post: 8th Oct 2011, 00:23 -
JPG to 18-hour video
By Aidan128 in forum Video ConversionReplies: 7Last Post: 18th Feb 2011, 06:21 -
FitCD thinks 43 minute video is 2 minutes long - ditto TMPGEnc
By natrap in forum Video ConversionReplies: 3Last Post: 2nd Aug 2009, 21:02 -
It took 11 hours with TMPGEnc 3 to make a 2 hour video folder
By nhbfan12345 in forum Authoring (DVD)Replies: 3Last Post: 9th Dec 2008, 14:18 -
Can't get my AVIs to make a 3 hour long dvd. :(
By Nicole78 in forum Video ConversionReplies: 5Last Post: 14th Apr 2008, 15:05
