Hi,
It's the first time I try ImgBurn. It's a great program and very light and easy to burn dvd's.
I've enabled the graph feature which can build graphs readable by DVD Info Pro.
Here is the graph:
How can I see if it's a very good/good/bad burn (the disc is perfect, and plays fine)??
You can check the quality of the burn by using the PI/PO test in DVDInfoPro. There's a guide about interpreting the scan at the ImgBurn forum (which still appear to be down, BTW).
Also, I wasn't aware that "2x" was a typical/standard burn speed. It's usually "2.4x", as t0nee1 mentioned.
Also, from my memory of my past grah data, there appears to be an awful lot of "movement" in the Verify graph. Maybe post a burn log, and maybe something will stand out (I'm by no means an expert, but I've used ImgBurn & read the forums, so I'm aware of most of the basic or "noob" errors).
Jim
ImgBurn
By didikai in forum Newbie / General discussionsReplies: 10Last Post: 17th Apr 2012, 23:18 -
Nero vs ImgBurn: Why is ImgBurn preferred?
By usually_quiet in forum Authoring (DVD)Replies: 31Last Post: 28th Aug 2010, 18:47 -
Why doesn't my imgburn program work this time?
By vladorlok in forum DVD RippingReplies: 19Last Post: 14th May 2010, 21:25 -
IMGBURN HElp !! Please help
By rockonvidtrade in forum ComputerReplies: 1Last Post: 26th Feb 2010, 14:39 -
Upgraded to ImgBurn 2.2 - Now "ImgBurn Shell Ext" No Longer Works
By Cool Breeze in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 11th May 2007, 11:05
