    Dec 2003
    belgium
    hey guys, ive downloaded this video from internet which i hoped it was on english, my surprise was when i saw the video and realized it was in french.... then again, i managed to found the very same video in english but in lower video quality, now my question: is there a tool that allows me to rip the audio from that video NUMBER 1 and paste it back to that video NUMBER 2 with higher video quality...?
    by the way the video is just a "movie clip"...
    thaxxx to you all, hope to hear from you soon
    Apr 2004
    Miskatonic U
    If they are both avi files, then virtualdubmod is a simple solution.
    Open the English video and click on Streams->Streamlist. Click on your audio track, then click on Save WAV and save the audio track to disc.
    Open the French version and click on Streams->Streamlist. Click on Add, and select your English audio. Click on the French audio track, and click on Disable. Click OK. Click on File->Save As, and save a new version of the video, with English audio.
    Caveats :
    The two videos must have the same framerate, running time and start at the same point for this to work first time. If they don't you will have to adjust for the differences.
    If the English audio is VBR MP3 you should convert it to CBR MP3 when you save it.
    Read my blog here.
  3. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Yes there is. Until you've dug out more, with respect to what kind of "movie clip" you're actually dealing with, that's about as precise answer it's possible to give you.
    I suggest you start with disabling "Hide file extension of known file types" in Explorer. (Tools, Folder options)
    Making the assumption it's in fact AVI video, the tool to use is VirtualDubMod.
    1 Load good audio AVI, Demux audio stream from the stream list.
    2 Load bad audio AVI, Delete audio stream.
    3 Add audio stream, selecting the saved audio from step 1.
    4 save new AVI with both audio and video set to direct stream.
    /Mats
    <edit>Bah, I would trust guns1inger to beat me to it! </edit>
    Dec 2003
    belgium
    Caveats :
    If the English audio is VBR MP3 you should convert it to CBR MP3 when you save it.[/quote]
    hey thaxxx for respondig, now, talking about the 2 videos... this is what they look like
    video 2 good image, french audio
    file: 551 Mb (551 Mb), time 0:47:00, type AVI, 1 stream(s) audio, quality 68 %
    Vídeo : 551 Mb, 1641 Kbps, 25.0 fps, resolution 720*576 (4:3), XVID = XVID Mpeg-4, Not verify
    Audio : 109 Kb, 128 Kbps, 48000 Hz, 2 channels, 0x55 = MPEG Layer-3, Supported
    video 1 low image quality, good english audio
    file : 468 Mb (461 Mb), time 0:46:58, tipo MPG, 1 stream(s) audio, quality 55 %
    Vídeo : 386 Mb, 1150 Kbps, 25.0 fps, resolution 352*288 (4:3), MPG1 = MPEG 1 (VCD), Supported
    Audio : 75 Mb, 224 Kbps, 44100 Hz, 2 channels, 0x51 = Mpeg-1 audio Layer 2 [0xc0], Supported
    now you said something about adjusting the framerate and running time, how do i do that? with virtualdubmod??
    i did try to do what you said, everything works well untill im ready to save the final video with the audio file from the other video, it gives me this error message
    error decompressing video frame 0
    the source image format is not acceptable
    error code -2
    see...im lost there...
    well hope you can help me
  5. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Sure you set video to Direct stream copy (under the Video menu)? If not, you're trying to save as uncompressed.
    Both videos seem similar enough that it may work without further processing.
    One odd thing is that the French audio is 109 kB! Can't be...
    /Mats
    Dec 2003
    belgium
    /Mats
    hey i did what you told me and it actually works, you were right about direct stream copy, i was trying to save it as uncompressed...
    so, thank you very much again, and from now on ill know who to call when problems arrive...
