I have recently bought a Creative Zen Vision M, which is rather splendid. One frustration I am having is that I have some Xvid files which have an AC3 soundtrack, which the player does not support, so I need to convert the audio stream.
I tried START as recommended elsewhere on this site, but that led to the audio being out of sync, and the resulting files kept crashing WMP, so I wasn't about to risk them on my player.
Is there any other tool, which will recode preferably just the audio, or the whole file to a supported format.
(supported video formats are DivX, XviD, MPEG-1, MPEG-2, MPEG4-SP, WMV9, Motion-JPEG - supported audio formats are MP3, WMA, WAV)
Any advice gratefully received.
Results 1 to 9 of 9
If you have AC3 ACM Decoder and LAME MP3 installed you can use Virtualdubmod to do this.
Open the avi and click on Streams-StreamList. Right-click on the audio track and select Full Processing. Right-click again and select Compression. Select LAME MP3, and set a bitrate and sample rate. Click OK. Click on Save WAV, and save your new audio track. Click on Add, and load the track you just created. Click on the AC3 audio track and click on Disable. Finally, right-click on the MP3 audio track and select Direct Stream Copy. Click OK.
Click on File->Save As to save a new version of the avi file, with MP3 audio.Read my blog here.
I saw that thread in my search, but as the words
The source AVI files are not changed in any way, -
Originally Posted by guns1inger
Originally Posted by Soopafresh"Art is making something out of nothing and selling it." - Frank Zappa
That seems to have done the trick just dandy.
Thank you all for your help. I shall now sit on the train tomorrow and enjoy my new toy!
AutoGK: stopped converting/a MP2 audio to MP3 [TV cap--> xvid/avi encodes]
By bruckwine in forum Video ConversionReplies: 7Last Post: 18th Jun 2010, 00:46 -
Converting AC3 in a video to MP3
By LittleJohny in forum Video ConversionReplies: 4Last Post: 4th Jun 2010, 20:21 -
Audio out of sync after converting AC3 to MP3 in AVI with VD
By huykin in forum AudioReplies: 6Last Post: 1st Oct 2009, 13:27 -
XVID AC3 TO MP3 Conversion problem help!
By sere83 in forum Video ConversionReplies: 4Last Post: 3rd Nov 2007, 14:55 -
Losing audio data converting AC3 to MP3, Help!
By blueprint in forum AudioReplies: 8Last Post: 24th May 2007, 14:55
