When I try to play some SVCD's the display says PBC, picture is black and only first 2 secs of sound is playing? I have tried to press everything on the remote but nothing happens!
Please help!
I use VCDgear to convert from bin/cue then Nero 5.5.3.5, Standard compliant SVCD setting. If I burn direct from bin/cue same thing happens.
Usually bitrates from 1900-2400kb/s. All other SVCDS (without PBC showing) works perfectly fine!! -
Hi!
If you press '1' instead of 'play' on your remote, does that fix it?
Chances are that it won't, so it's not really down to your DV-444, just a coincidence!
I'm having a few problems with SVCD playback on my DV-444 but I think I've just about sorted them.
As a general suggestion, try downloading the SVCD clip from this site (in tools or SVCD <--) and then burning it with Nero. If it fails, try a different burning software ..... VCDEasy is a good benchmark.
Have fun!
Sue xxx
Hey ... guys.
Can you use the search function on your SVCDs? Try it out and tell me your results ... will ya? Thanks. -
Hey,
I posted something that fixed mine and apparently others a few links down this page. Give it a try...can't hurt.
Pioneer EV61DVD Can't Play DVD-9
By hitgurl in forum DVD & Blu-ray PlayersReplies: 2Last Post: 8th Mar 2010, 06:33 -
my panasonic standalone dvd can't play pal dvds...but can play pal svcd's
By stoico1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2009, 17:46 -
DVD will play in PIONEER Standalone but NOT Recognise in...........
By rockonvidtrade in forum Authoring (DVD)Replies: 1Last Post: 13th Apr 2009, 00:14 -
Does Toshiba HD-A2 play SVCD's?
By desertfox in forum DVD & Blu-ray PlayersReplies: 3Last Post: 20th Aug 2007, 10:40 -
Pioneer XV-DV313 will only play back up copies of dvd's, not originals?
By moults in forum DVD & Blu-ray PlayersReplies: 6Last Post: 6th Aug 2007, 15:17
