Hello, I am newbee and trying to do a conversiton from DVD to DVD-Audio. The reason I reason I am trying to do this is bacause I got a new car that accepts DVD-Audio discs and it has a virutal 7.1 sound system I want to take full advantage of.
I know how to rip dvd by chapter by using DVD Decrypter so I can get the songs out from the movie. Music DVDs. Then I am lost on what tools I need to convert. I have read the forum on ideas but nothing matches mine.
any help would be appreciated and thanks in advance for the advice.
Can someone move this to the correct forum, if i put it in the wrong section. I would really like some help with this.
You'll need to get your hands on a DVD-A authoring tool.
http://www.discwelder.com/ -
Adobemans DVD-A GUI
http://home.comcast.net/~adobeman/DVDAGUI/
Simple freeware DVD-A authoring
DVD-Audio Solo
http://www.cirlinca.com/products.htm
Fully working free trial edition will author up to 4 full DVD-Audio discs. Full version only $35 US. Supports graphics.
Both support the full spectrum of bitrates and sampling frequencies, as well as multiple titles on a single disc.
Is a 44.1 KHz audio capture OK for a compliant DVD?
By c627627 in forum Capturing and VCRReplies: 8Last Post: 23rd Mar 2010, 05:29 -
DVD recorder conversion to compliant DVD
By snafubaby in forum Authoring (DVD)Replies: 4Last Post: 27th Dec 2009, 05:57 -
How do I make an MPEG-2 dvd compliant file into a authored dvd?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 13Last Post: 12th Mar 2009, 16:10 -
No audio in dvd compliant mpeg 2 files
By Bertieboo in forum Video ConversionReplies: 6Last Post: 14th Nov 2007, 16:35 -
WMV to DVD compliant MPEG2 - TDA3 or DVD Maker - what is the right way?
By MagicSparky in forum Video ConversionReplies: 5Last Post: 23rd Aug 2007, 13:27
