I've got an xvid-movie, now I want to make a sample of this one in exactly same quality. What program would I use? Let me take an example, if I got a dvdr i can make a sample from this with example Chopper XP. What is the solution with xvid?
virtualdub, select start and stop, select video->direct stream copy, select audio->direct stream copy, file-save as avi.
<-- or click on EDIT or Tools in the secret menu to the left.
Software to make sample of movie
By cyberlion in forum EditingReplies: 5Last Post: 7th Aug 2010, 07:32 -
[SOLVED!] Converting Variable Sample Rate to Constant Sample Rate
By Midzuki in forum AudioReplies: 17Last Post: 24th May 2009, 11:26 -
How to make a sample of an AVI file pls?
By incrediblej in forum EditingReplies: 5Last Post: 20th Dec 2007, 08:59 -
Easiest way to make a 16:9 DVD into a 4:3 XViD?
By bconnolly in forum DVD RippingReplies: 10Last Post: 31st May 2007, 16:54 -
How to make xvid of VTS with multiple pgcs?
By Talayero in forum DVD RippingReplies: 0Last Post: 30th May 2007, 10:55
