Hi,
I would like to play HD DVD FILES on a standalone player.I have Pioneer 393S which plays everythinmg but when i insert these files on the dvd , there is no video just the audio.Please advise.
My guess that the resolution is too high. You'll need to re-encode down to 720 by 576 or lower resolution.
FWIW My Phillps is the same way. -
Hi,
Thanks for thereply.I understand that it is not possible to play these files through the conventional player.What about media centre pc.I plan to buy a HITACHI plasma.Please advice regarding the specifications for a mediacentre pc.
Thanks -
if you going to buy HITACHI plasma TV .try to invest also in a HD-DVD player so you can take advantage of your new TV
http://www.bhphotovideo.com/bnh/controller/home?O=NavBar&A=search&Q=&ci=12836 -
The specifications for the mediacenter PC will depend on what you want to do. OTA analog, OTA ATSC, How it connects to the TV.
Do you only want to play back clips to the TV? Then a Media center isn't really needed. Just a TV with for example VGA input so you can hook it up and use it as a Computer monitor. Want to record from OTA then you need a tuner card, dual tuner would be best. Watch one record a different one. Decide whether analog only or analog and digital.
Record from cable or Satellite in HD. Then you'll need to find a card that accepts for example Component or HDMI input and has a IR blaster that can control your box. Not a cheap task. You can't connect the coax out on those boxes and ghet anything but SD.
Have you looked at DVD and DVD resolution clips played through a upscaling player on a HDTV? Could be good enough. That depends on your TV size and other factors. I find I'm happy with NTSC or PAL resolutions on my HDTV (32"). YMMV
Many here are happy with the Oppo upscaling player, do a search. Good Luck -
Originally Posted by MJA
from Satellite TV Showtime and HBO HD channel once in a while. the older stuff from Monsters HD and Universal HD and HDNet and the networks more often. Movies that way would be Please Don't Eat the Daisies, Rodan. Shows from NatGeo HD, A&E HD, Discovery HD, World HD and so on. I'm not expecting any of them to be on a HD Disc anytime soon.
I also watch the Networks in HD and a lot of SD content on other channels. The content just isn't there for me to want a HD player.
Need codes to convert Australian DVD player into a multi region DVD player
By Seajacb123 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Oct 2010, 01:00 -
Burned DVD Plays On Laptop, LG Player; Does Not Play On Panasonic Player
By Valentin in forum Authoring (DVD)Replies: 15Last Post: 18th Jul 2010, 12:55 -
Subs work on PC/VLC Player...but don't show up on dvd player
By bgart13 in forum SubtitleReplies: 9Last Post: 22nd Aug 2009, 18:06 -
my player blu ray disk samsung bd-p 1400 not player my avchd on dvd-rw !?
By LEONESVIZZERO in forum DVD & Blu-ray PlayersReplies: 10Last Post: 4th Apr 2008, 09:15 -
How Can I Convert Real Player Video Files To Make Them DVD Player Compatabl
By Lennoxtown in forum Video ConversionReplies: 8Last Post: 17th Oct 2007, 06:05
