my sister is drivin' me crazy!!!
she always downloads Massenger to my PC and i hate that!!!!!!
how can i block the MSN site from access??
i'm using Internet-Explorer 7
Thank you!!!
If you change the administration rights on your computer you can prevent any programs from being installed without your knowledge.
Be aware that if you set your computer incorrectly you could lock yourself out of being able to add or change programs.
Go to the control panel and you will see an icon user accounts. Use this to add a new account for your sister giving her limited rights do not give her administration rights.
Then on your account password protect it.
You should then be able to add or remove programs but you sister will not if you do not let her log on with your account. -
sounds good!Originally Posted by GilbyGood
Thanks man!
but tell me... if she'll log into her account - will it stop the runnin' processes in my account? -
Yes. You have to log off before she can log in.
The way around this is to create a new account for you with limited rights and let her use that one and keep the original account for adding programs. -
I can readily think of 3 ways and I would try them, in this order:Originally Posted by GangstaRap
1. Ask her not to download it.
2. Tell her not to download it.
3. Use technology to prevent her from being able to download it.
1 & 2 are obviously very quick, easy and relatively pain-free as far as techo knowledge goes
3 can be done in a number of ways. Depends how forceful you want to get.If in doubt, Google it.
ISP problem - some website pages load, other website pages don't
By PartingShot in forum ComputerReplies: 15Last Post: 7th Sep 2012, 00:42 -
To block sites
By Jomapil in forum ComputerReplies: 13Last Post: 24th Apr 2012, 20:12 -
DV pixel block help
By cg_society in forum EditingReplies: 3Last Post: 26th Oct 2011, 10:42 -
Digital block out
By homie241 in forum RestorationReplies: 9Last Post: 21st Apr 2011, 07:40 -
Block a file
By Jomapil in forum ComputerReplies: 2Last Post: 11th Nov 2010, 04:50
