Hi guys!
I have connected an old hitachi vcr with a Hauppauge usb tv tuner,in order to capture video.
I used the WinTV2000 for that work and the first problem I noticed when I played the uncompressed video in my computer,is that the voice comes first and the picture after.Does anyone know how to solve this?
The second problem that i have is when i try to encode the video with TMPGEnc 4 XPress.In the encode bitrate settings,I can't use average video bitrate higher than 9200Kb/s.As far as i know higher bitrate reduces the quality loss.Does anyone know how can i fix this?
Thanks,and sorry if my english aren't so good!
PS:What 's the difference between interlace and progressive framerate?
Doesn't the Hauppage card capture to mpg already? Why do you reencode in that case? If not, what format do you capture to?
9200 is max allowed DVD bitrate - That's probably why TMPGEnc refuses to go higher.
/Mats -
No idea - As I have hardware mpg encoder, so what I capture can be authored to DVD without processing. Never a sync issue.
If it's constantly off sync by the same amount, I think there's some way in TMPGEnc (not familiar with Express tho) to add audio delay to compensate.
/Mats
Video capture, editing & redndering in 1680x1050 - BIG PROBLEMS
By casparticus in forum Newbie / General discussionsReplies: 2Last Post: 19th Aug 2011, 17:57 -
Best video capture software? Is AVI better for capture? Is TV screen better
By johnharlin in forum Capturing and VCRReplies: 5Last Post: 21st Feb 2011, 08:17 -
video capture problems - HV20 camcorder is controlled but no video capture
By chebowitz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 27th Feb 2010, 11:49 -
Problems with video capture
By DrRST in forum Newbie / General discussionsReplies: 9Last Post: 11th Nov 2008, 22:48 -
video capture problems in ulead videostudio 11
By scott114 in forum Newbie / General discussionsReplies: 0Last Post: 23rd Jul 2008, 16:49
