I've been searching forums for hours, can't seem to find the exact answer I need.
What I have is a Handycam DVD-R with a VIDEO_TS folder that contains IFO, VOB, and BUP files. I would like to convert these files into one AVI file (or another compatible file with PE) that I can import into Adobe Premiere Elements for editing and coding for the Internet.
I've tried DVDdecrypter, MPEG Streamclip 1.1, some other freeware software, and also changed .VOB files to .mpg but nothing is working. Is there an easy way to make this conversion? I'm on a tight budget, so cost is prohibitive.
PE supports the following formats: MPEG-1, MPEG-2, MPEG-4, H.264, DV, AVI, Windows Media®, QuickTime, JVC Everio MOD (import only), 3GP, ASF (import only), WAV, WMA (import only), Dolby® Digital Stereo, PSD (import only), JPEG, PNG (import only), DVD.
If anyone has a solution, some advice, somewhere for me to turn for help, I would be most appreciative. Frustrated at this point, but cheerfully plowing forward.
Thank you very much in advance.
2headedboy
Results 1 to 1 of 1
Premiere Elements 3 Export to DV-AVI or m4v file?
By bowmah in forum Newbie / General discussionsReplies: 2Last Post: 9th Oct 2008, 19:12 -
Adobe Premiere Elements 4, file too small?
By dredle1 in forum Video ConversionReplies: 4Last Post: 27th May 2008, 18:55 -
Converting VOB to DV AVI for Premiere 6.0
By wasimismail in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 22Last Post: 9th May 2008, 23:20 -
Editing a dvd using Premiere Elements 3 IFO??!! BUP??!!
By wiseeye1 in forum EditingReplies: 2Last Post: 2nd Feb 2008, 10:07 -
EDIT! Program only converting 1st VOB file?
By chronic777 in forum DVD RippingReplies: 2Last Post: 17th Aug 2007, 05:14
