I am in the process of making a corrporate presentation.
I have a video in MPEG2 format, which is very good in quality.
But it has some unwanted sound.
I want to remove the audio off it and include my narration.
How can I achieve it.? I dont want to convert it to avi as I will losse quality.
Which tool can I use to achieve this...?
Any help wud be appreciated...
Read thru this site - do a search for demux mpeg video or something to that effect. Or look to the "tools" section to the left.
Tons of info on this site - you only have to dig further.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
If you already have a synchronous encoded audio source, an easy way to do it is to open your video in TMPGEnc MPEG Editor and browse for the file desired as audio track. Then import and output it as MPEG stream with default (automatic file type detection) setting. You can do almost the same in TDA (in this case output will be a DVD folder).
Mpeg-2 editing confusion...
By amtt in forum EditingReplies: 41Last Post: 3rd Mar 2011, 17:47 -
editing program - sd mpeg
By devdev in forum EditingReplies: 5Last Post: 21st Oct 2010, 12:53 -
MPEG editing
By mkr10001 in forum Video ConversionReplies: 6Last Post: 15th May 2010, 23:54 -
Keyframes and MPEG-2 editing
By ffooky in forum MacReplies: 8Last Post: 5th Feb 2009, 04:17 -
Mpeg-2 is not good for editing
By totalfreedom in forum EditingReplies: 13Last Post: 8th Mar 2008, 16:01
