  1. Is there any software l can use to change black and white photos to colour which l have on my computer.
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Are you good at painting?
    Luminance can be fixed and you can apply color pixel by pixel.
    Google "Adobe Photoshop" or if you are heavy geek try "Gimp".
    USA
    You should be able to colorize a scanned photograph with a graphics editor like PhotoShop, or others that let you mask a area off and tint it. You would need to select just one part at a time and apply like a 10% tint, then go on to the next part and color. But it's tedious work and the results really don't look that good.
  4. Member ahhaa's Avatar
    Feb 2005
    Michigan USA
    these guys have a free 'easy' 30 day trial:
    http://www.recolored.com/
    Googling 'colorize black & white' will get you half a dozen hopefuls
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Give your black and white photos that authentic "Turner Classics" look. Off skin tones, over saturated clothing and purple skies.
    All of these are valid suggestions, but it will only look good if you have a good eye. Nothing will automate the process and give you good results.
    Read my blog here.
  6. You can tint them easily enough, if that's good enough for you.
  7. Member ahhaa's Avatar
    Feb 2005
    Michigan USA
    actually, I'd kinda like to turn several color shots B&W, but I haven't found a digital TRI-X grain solution that I like...
