I try to burn a movie onto dvd, but I got a problem: the audio seems to run faster than video, while my movie in .avi format is correct.
Please help me out.
Results 1 to 9 of 9
I have Nero 7, dvd burner pioneer dvr-111d.
when I run gspot for the movie i burnt I got a screen as the pix I attached.
untitled.bmp -
Try convertxtodvd instead.
And this is no editing. Moving you. -
thanks alot for your help, it works now.
But when I used convertxtodvd, it takes about 30mins extra to burn into dvd, beside the same amout of time that Nero used for whole process. Why do nero cause the problem? and is there anyway to make the process faster and shorter?
Once more time,thanks for your help. -
rules of thumb
#1 nero does a lousy job of converting
#2 quality takes time more, the better the quality the longer the time
#3 mulit-step processing gives the best quality, and takes LOTS of time
get used to it your going to hear it a lot
#4 some people will answer with the best description they know how to give, others will just toss out a program name, expect you to grab it like a life preserver , without giving any info on how to use it -
others will just toss out a program name, expect you to grab it like a life preserver , without giving any info on how to use itRead my blog here.
I gave plenty of info and frame serving ( which is not a simple solution ) i'm still reading up on that and getting no where fast with my attemps, was not even suggested in the begining.
at lest manono did some reading and came back with a post about MKV format being a problem to convert,
MP4 video playing at a faster rate than audio
By Teroxgt in forum Software PlayingReplies: 0Last Post: 21st Jul 2011, 01:15 -
avidemux- audio comes out faster than video
By DaneClark in forum EditingReplies: 1Last Post: 11th Jul 2009, 18:41 -
AVI to mp4, no audio or video much faster than audio
By michaelab in forum ffmpegX general discussionReplies: 2Last Post: 21st Nov 2008, 12:48 -
Computer question, what makes them encode faster, unrar faster etc.?
By willhenderson in forum ComputerReplies: 5Last Post: 30th Sep 2008, 22:21 -
Audio faster than video
By WI2CA in forum Newbie / General discussionsReplies: 4Last Post: 15th May 2007, 23:05
