Hi all,
A few days ago I purchased a Asus DRW-1608P3S, I am currently burning a dvd (data) and I burnt a dvdr (movie) but when I was burning the mvoie on average it should take 5 mins, this took almost 30 mins. When it was burning the read buffer and buffer level where not steady they where bouncing all over the show. On my previous dvd writers they did not do this they stayed static at 100%.
Could this be a faulty dvd writer drive, or soemthing else?
Results 1 to 12 of 12
Check your dma - instructions here:
http://club.cdfreaks.com/showthread.php?t=101616
and post back to let us know what you found out. -
Hmmmm - was hoping for a simple solution. It could be something simple like the media you are using is not recognized by the drives firmware and is defaulting to a 2x or 4x default strategy. What media are you using and what firmware came with your drive? I think the most current stock firmware is 1.24 if I recall.Originally Posted by narl
Im using nero to burn and dvd decrypter to burn as well.Originally Posted by OneSickPup
I tried to update the firmware but it already has the latest firmware on it. -
Originally Posted by oldandinthe way
Good point! ASUS and Pioneer drives of this type require 80 wire - 40 conductor cables.
http://www.centralcomputers.com/commerce/ccp28952--2320440-3-18-ide-uata-100-18--3-con...scabideu3s.htmOriginally Posted by narl
If that's the ide cable you've been using they can fail. Buy a new 80 wire ide cable and see if that fixes the problem. It's very cheap! Also use IMGBURN instead of NERO BURN & DVD DECRYPTER to burn dvd media. DVD DECRYPTER is no longer updated but IMGBURN is. The author is the same for IMGBURN & DVD DECRYPTER.Originally Posted by narl
www.imgburn.com
The imgburn website seems to be down at this time. Try later to access it. If using a new 80 wire ide cable doesn't solve your problem and the IMGBURN doesn't work as well then your drive is probably defective.
UDMA4 mod eis required!
*** Now that you have read me, do some other things. ***
I think My ASUS DRW-20141T Is Dieing??
By xintensex in forum DVD & Blu-ray WritersReplies: 6Last Post: 20th Oct 2010, 01:58 -
Magnum DRW 9500
By Topp in forum DVD & Blu-ray RecordersReplies: 0Last Post: 20th Feb 2009, 21:31 -
Asus DRW-1814BLT Freezing Computer While Working
By mightymo77 in forum DVD & Blu-ray WritersReplies: 5Last Post: 1st Nov 2007, 11:54 -
New Asus DRW-1814BLT Sata 18x Burning slowly Nero7
By DAVE440 in forum DVD & Blu-ray WritersReplies: 5Last Post: 15th Sep 2007, 02:16 -
ASUS DRW-1814BLT SATA Cables needed?
By Choppa in forum DVD & Blu-ray WritersReplies: 3Last Post: 14th Aug 2007, 00:21
