I have seen this version mentioned, but not at the TMPGenc website.
Is it an official release?
What has it got over 2.02 and where can i get it?
You can get version 2.5 here : http://www.tmpgenc.net/
I believe it's on a different site because 2.5 is kinda the pre-release for the full PRO version which will be appearing soon.
What it's got over 2.02 is ...... not much!
The main addition is the Wizard Interface that guides you through the encoding process - sort of like helpful templates!
Some of the actual encoder settings have been updated to make them 'easier' to get good results.
Hope this helps!
Sue xxx
And it has allot of bugs, especially with amd processors and batch encoding, I don't recommend it.
AMD processors? buggy? could this be my problem?
When i do batch encoding it nearly never completes properly resulting (usually) in TMPGEnc just bombing out..... -
It also has a pretty cool sort of built in BR calculator.
Blow me for faster replies.......
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
Tmpgenc Plus & TMPGEnc Batch List Creator help Please
By VOYAGER2009 in forum Video ConversionReplies: 2Last Post: 4th Jul 2010, 08:57 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
