Hi there, i have 3 grandchildren and trying to make a dvd with menus out of their christening and school days, each kid have his/hers AVI Videos and i am thinking of making one dvd but with 3 menus so i can pick which menu to play.
What do you recommend and which software and codecs to use.
thank you
Ulead Movie Factory is fairly cheap an easy to use. Has a 30 day trial like most software.
Video files on DVD's with menus are MPEG2, any all in one app like the one I mentioned above will have a MPEG2 encoder.
If you list the type of files they are you can get some better advice, if you don't know use use G-Spot . Don't laugh... :P
Dazzle dvc100 w studio 12 does it capture AVI 1 or AVI 2 or DV-AVI
By st711 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 17:30 -
avs (avi to avi) ends up out of sync ... winavi output file too big
By mandy in forum Video ConversionReplies: 1Last Post: 21st Aug 2009, 05:56 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 15:38 -
ffmegX v0.09w and converting avi videos into avi.ff.avi videos
By paddymick in forum ffmpegX general discussionReplies: 2Last Post: 2nd Nov 2007, 23:10 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 12:49
