    Mar 2007
    I ve been looking around, dvd shirnk didnt seem to help the problem, im tryin to compress some of my full dvds down to from about 4gb down to 200-500mb to fit onto my sisters imax. it is kinda like an ipod but cheaper and smaller hard drive.
    thanks for any help
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    well what format does it require ? what resolution ?
    anyway - a 2 hour movie at 200mb is not going to look particularly good anyway ....
  3. Член BJ_M's Avatar
    Jul 2002
    Canada
    this must be it -- the t9000 . http://portable.geek.nz/?q=node/66
    here is the instruction manual ... http://www.portable.geek.nz/PMP.pdf
    this unit basically supports everything ...
    I would use super and encode a movie to xvid 352x240 res. -- you will have to crop it and make it fit a 4:3 ratio screen IF the source is wide screen .... audio should be 2 channel ac3 (which the dvd prob. already has) ..
