    Mar 2007
    Canada
    I recently downloaded ffmpeg from http://ffdshow.faireal.net/mirror/ffmpeg/ffmpeg.rev8435.7z
    How do I use it do any video conversion.
    WHICH command prompt to use???
    Most websites give commands like
    ffmpeg -i /inputfilenameWithAddress.extension /outputfilenameWithaddress.extension
    but the forward slash does not work in Windows Command Prompt.
    Please help
  2. Member Soopafresh's Avatar
    Jan 2004
    That's a big question. I'd suggest you start with downloading BackgroundCMD, which will give you a command prompt in any folder you navigate to - just by right clicking.
    http://www.roggel.com/NGNeer/BackgroundCMD/
    You don't need to use \ or / too much with ffmpeg. Most windows prompts use \ , as in
    c:\windows\system32 to point to that folder on the hard drive.
  3. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Of course, there are also a number of GUI interfaces for ffmpeg, if the command-line interface seems intimidating. One such GUI is WinFF, and others can be found in the Tools section to the left.
    Mar 2007
    Canada
    Thanks for the replies!
