Thi is from the GFD guide:With dvdauthor as authoring engine you may use ready muxed material also, if it is compatible with dvdauthor (contains navigation packs and continuous time code!). That applies e.g. also to VOB files, if these contain only one film (title), thus if a constant timecode is present. If the (single!) film is distributed on several VOB files, these can simply be "copied together" into a large one from the command line (and thereby renamed in mpg). Example:
copy /b VTS_01_1.VOB + VTS_01_2.VOB + VTS_01_3.VOB NewFilm.mpg
The rename to mpg is always necessary, since in GFD only files with the extensions mpv, m2v, m1v and mpg are shown in the source window.
http://download.videohelp.com/gfd/Help/RawMaterial.html
Results 31 to 34 of 34
he didn't start out with vobs
his files would NOT work that way
and neither have my mpeg files
just because the manual states something will work under a given set of condtions, doesn't mean the 'real' world normal conditions are the same
User guide for super video converter
By ocko in forum Newbie / General discussionsReplies: 2Last Post: 20th Aug 2012, 05:32 -
What is AVI(for pocket PC) in Super?and keep aspect ratio in Super ?
By SingSing in forum Video ConversionReplies: 2Last Post: 19th Dec 2009, 21:05 -
SUPER - is it really super? (a behind-the-scenes look)
By BaronJT in forum Video ConversionReplies: 5Last Post: 2nd Aug 2009, 08:29 -
TV Guide/Guide Plus+ After Feb. 2009
By handyguy in forum DVB / IPTVReplies: 0Last Post: 30th Oct 2008, 10:34 -
SUPER
By Flying Doctor in forum Video ConversionReplies: 17Last Post: 6th Jan 2008, 06:52
