Hi guys, I want to burn a cd and I have all my tracks in both formats WMA and MP3.
Which format will be the better to burn the cd and why?
thanks.
Impossible to answer. Take the one that sounds better, if you can hear any difference. Or wait for the wma/MP3 evangelists to come here to throw themselves at eachothers throats
/Mats -
From experience I can tell you WMA is superior to MP3 at lower bitrates, 64kbps or less. The lower you go the bigger the gap. Hard for me to hear a difference once you get up around 128 and techinical articles I've read state the same.
Having said that use whatever format your device supports, most likely MP3. Do they even make a WMA CD player?
Or wait for the wma/MP3 evangelists to come here to throw themselves at eachothers throats.
Of course, I probably should ask if your intent is to create a data CD, or an audio CD.
If cameras add ten pounds, why would people want to eat them? -
Many people consider 160 Mpbs WMA to be as good as the original CD. 192 Mpbs MP3 is considered as good as the original CD as well. This should give you an idea that WMA is, in theory, better than MP3 at a given bitrate, but there are people who will argue that both are bad at any bitrate and so on.Originally Posted by thecoalman
Yes, there certainly are portable WMA CD players. Such players also support MP3. Take a look at a Best Buy or similar store for a selection of surprisingly cheap models. -
Then neither WMA or MP3 are any good.
You need 41.1kHz 16bit PCM (wav) for an audio CD.
You'll need to convert whichever sounds best into WAV for your CD
wma to mp3
By rjc7394 in forum AudioReplies: 5Last Post: 14th Sep 2010, 14:00 -
Help with MOD to mp3/wma
By Bluntz11 in forum AudioReplies: 10Last Post: 14th Apr 2009, 20:12 -
Is it possible to convert Mp3 to wma?
By t_jay17 in forum AudioReplies: 8Last Post: 17th Feb 2009, 16:32 -
Converting mp3 to wma with Vegas 6.0
By solarblast in forum AudioReplies: 2Last Post: 1st Oct 2007, 06:50 -
wma to mp3
By rjc7394 in forum AudioReplies: 0Last Post: 8th Jul 2007, 19:28
