Hello all i just purchased some dvd-r dl 8.5 gb disks, but it seems when i burn some of the larger movies i am missing files not included or endings of movies are not being recorded, i wasted a number
of disks today already trying to figure this out.... It is usually when the movies come in
folders Disk1 and Disk2 this happpens... I am using Nero 7.7.5.1 Platnium
Is there settings i have to ajust or change
Mack18
1st: Never use nero for burning DL media.
2nd: You should be using +R DL as -R DL was not designed for DVD VIDEO.
3rd: Alway's use Verbatim +R DL.
https://forum.videohelp.com/viewtopic.php?t=321943&highlight=
Not sure what you mean byOn the same original disc ?It is usually when the movies come in
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 04:16 -
Dual Layer problem. Layer break issue...
By papegoja in forum DVD RippingReplies: 23Last Post: 9th Jun 2010, 23:52 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 10:00 -
dual layer DVD-R in single layer burner?
By snafubaby in forum MediaReplies: 5Last Post: 4th Oct 2007, 14:39 -
Help on Dual Layer DVD
By mn072065 in forum DVD RippingReplies: 9Last Post: 16th May 2007, 10:36
