Is ther a way to get a video file and many audio (MP3) files on to one DVD.
AND get them to play in a standalone DVD player?
What I would like, if possible, is to have such a disk be placed in a standalone DVD player. And, as with a "regular" DVD, a menu pop up giving the viewer the possibility of picking between the video file and any of the audio (MP3) files.
BTW If this IS possible, then can it be done with NERO 7?
You can encode the mp3 with https://www.videohelp.com/tools?tool=Audio_DVD_Creator into a playable DVD.
Use TMPGenc DVDauthor to extract the VOB files from the above and DVD of your choice, and combine them into a DVD with the menu and chapters that you are going to create.
Press play. -
1- Make sure that your player can play MP3 format.
2- Is your Audio associated with video, or you have one video and many audio files to play with the same video? -
If I'm reading the OP correctly, Ensign wants to have at least one video file, probably in DVD-Video format, BUT have the person playing the disc be able to select the background music from a menu.
Theoretically, I think you could do the whole thing through DVD menus. You wouldn't be able to use separate MP3s and would likely have to have a version of the video encoded with every single song you planned to use, though.If cameras add ten pounds, why would people want to eat them? -
If that is the case, check this web site:
http://www.puremotion.com/forum/viewtopic.php?t=6029
Go down the page. -
You want a DVD video with several choices of soundtracks?
Just author a disc using the video, and add as many soundtracks as you like as different "languages". You can select them using the audio track button on your remote.
However, standard DVDs don't use MP3 audio, your authoring app may convert it to AC3 for you, or do it yourself with ffmpeg, Besweet, etc.
How we can increase audio of a video file when we burn it on dvd
By nusratjaveid in forum DVD RippingReplies: 2Last Post: 5th Dec 2010, 22:35 -
How to add an mp3 audio file onto an mp4 video file?
By Tintin11 in forum RestorationReplies: 4Last Post: 4th Nov 2010, 06:01 -
How to combine video with audio file and replace audio with video files ?
By designbuyers in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2009, 11:12 -
How do I change audio codec on an already burned dvd/video converted file?
By klobb in forum AudioReplies: 5Last Post: 31st Dec 2007, 05:03 -
Converting VOB file to MP4 file. Video is perfect, audio is nonexistent.
By jdfrosty in forum ffmpegX general discussionReplies: 6Last Post: 17th Jul 2007, 18:31
