I'm using AutoGK, and i recently noticed that i can also add subtitles (Ctrl+F8 ).
how does it add the subtitles?
i mean - is it pastin' the subtitles permanently, or is it addin' it as a separate SRT file?
Thanx in advance!
Yes.
Each lossy compression results in quality degradation.
If you have to re-encode though, you do it anyway.
Need for hardcoded subs is such a scenario.
Personally I hate hard subs. -
45tripp, thanks for your help man.
i can live with subtitles in a separate file.
i just thought that if it won't hurt the video quality so be it but now that you've told me it does - i think i'll pass...
AutoGK: no subtitles in output
By Russ_in_Colorado in forum DVD RippingReplies: 6Last Post: 5th Sep 2011, 21:20 -
AutoGK not hardcoding subtitles?
By vangelon in forum Video ConversionReplies: 1Last Post: 18th Nov 2009, 06:56 -
autogk subtitles
By surfer in forum DVD RippingReplies: 10Last Post: 4th Apr 2008, 13:39 -
Separate Subtitles using AutoGK
By gl22 in forum DVD RippingReplies: 5Last Post: 27th Jul 2007, 13:25 -
No subtitles with the AutoGK
By wvpneto in forum SubtitleReplies: 5Last Post: 12th Jun 2007, 00:54
