I currently have a Belkin G, and it's OK, but not great. I'm thinking of upgrading. I'd like something which not only is compatible with G, but isn't slowed down by it, since I'll still be using my D-Link DSM-320 Wireless Media Server, which is G, on the wireless network.
Should I just get another G system? Which is best? I used to have a Linksys B system which was fairly dependable, but slow. I thought upgrading to G would allow me to stream video up to MPEG 2 over the network, but as we all know, advertised wireless speeds are much superior in theory to what they are in practice.
How good is G+, for example G with "Rangebooster" or other 108 Mbps systems? Which ones wouldn't be slowed down by the plain old G machine on the network?
Pre-N, with MIMO, looks sexy, but is it ready for prime time? Again, which manufacturers offer a system that not only is compatible with G devices, but also isn't slowed down by them?
Do not buy N draft gear. Wait until N standard is final.
Then get a N certified router. Buffalo and Linksys routers should be OK. -
N standard final will not be out until 2009 ... a lot of the preN (draft) equipment is very good - right now in fact ..
by 2009 , a lot of focus will be on IEEE 802.11s -- which is mesh networking (already used in such things as zigbee networks (and others) used for lighting and system control throughout buildings and houses)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
a good 2.4ghz router (do NOT get anything 5.4ghz) with extended range ant. will easily take care of a 3000+ house if in a decent location - otherwise use range extenders (though these tend to be more directional - i prefer just using multiple APs)
How to Download Videos streaming from mms:// protocol with *.wmv format
By MediaFan in forum Video Streaming DownloadingReplies: 14Last Post: 25th Apr 2018, 11:59 -
wireless Networking (router trick)
By stiltman in forum ComputerReplies: 0Last Post: 26th Mar 2009, 00:18 -
Does Windows 2000 do wireless networking good?
By zzyzzx in forum ComputerReplies: 11Last Post: 21st Oct 2008, 13:21 -
Networking for a moron -- wired and wireless.
By Xylob the Destroyer in forum ComputerReplies: 2Last Post: 23rd May 2008, 13:47 -
What is DDP ( Disc Description Protocol ) ?
By jjulio1 in forum Authoring (DVD)Replies: 1Last Post: 24th Jun 2007, 16:36
